Date/Time: Thu, 16 May 2024 03:14:14 +0000
How to make a vertical line (any tool) in the background / behind visible chart bars?
View Count: 683
[2020-01-05 12:41:23] |
User430957 - Posts: 6 |
How to make a vertical line (any tool) in the background / behind visible chart bars? The bars should be in the foreground, the vertical line (tool) in the background. I looked in SC and the documentation, but could not find how to do it. |
[2020-01-06 15:24:24] |
John - SC Support - Posts: 31666 |
Refer to the following setting and the one after it: Chart Settings: Draw Non-Highlight Chart Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
