Date/Time: Fri, 03 May 2024 07:42:15 +0000
Initial Balance problem
View Count: 1042
[2013-12-31 23:37:34] |
emp0804 - Posts: 31 |
I have the IB set to the first 5 mins of trading, when viewing a 5min bar the IB is correct, when changing the chart to view 60m bar the IB is inccorect.
IB Screenshot.jpg / V - Attached On 2013-12-31 23:37:07 UTC - Size: 140.51 KB - 373 views |
[2014-01-01 00:14:28] |
Yes of course. The chart bar timeframe must be no greater than the initial balance time period. There is no way around this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-01 00:15:04
