Date/Time: Mon, 13 May 2024 23:28:52 +0000
On Time Price Opportunity (TPO) Profile Charts - how do you change the settings to create
View Count: 1627
[2020-01-04 17:47:26] |
Jay Greenlees - Posts: 15 |
On Time Price Opportunity (TPO) Profile Charts - how do you change the settings to create separate profiles for the RTH session and overnight session? Please see the 2 attachments that show the profiles of the last several sessions on ES one attachment is a screenshot from another company that has the profiles on the RTH and Overnight sessions separate one after the other the other attachment is a screenshot on the profiles as how they appear on Sierra chart on the default settings which looks like the RTH and overnight sessions are combined into one profile How do I change the settings so that it will be more like the 1st attachment where the RTH session and the overnight session are separated? I have looked here https://www.sierrachart.com/index.php?page=doc/StudiesReference/TimePriceOpportunityCharts.html#Intro but do not see how to do that |
Overnight and RTH sessions seperated on Profile Chart - 1.jpg / V - Attached On 2020-01-04 17:46:09 UTC - Size: 430.48 KB - 479 views Sierra.jpg / V - Attached On 2020-01-04 17:46:37 UTC - Size: 501.35 KB - 819 views |
[2020-01-04 17:59:40] |
Profile Trader - Posts: 168 |
You will need to go into chart settings and setup for session times Start 09:30:00 End 16:14:59 Evening Start 16:15:00 Evening End 09:29:59 You can then check or uncheck the Use Evening Session or use Ctrl G to swap between seeing it or not. Hope that helps. Doug |
[2020-01-05 17:19:40] |
Hi--I think I found the correct setting to change Adjusted setting on Sierra for New Period at Day Session Start Now it shows both sessions (RTH and Overnight)side by side as separate profiles |
Adjusted setting on Sierra for New Period at Day Session Sta.jpg / V - Attached On 2020-01-05 17:19:18 UTC - Size: 542.79 KB - 386 views |
[2020-01-06 17:42:11] |
John - SC Support - Posts: 31602 |
Yes, that is the correct setting to have a separate TPO for the evening session, assuming that your Session Times are setup properly. For reference, you will find the documentation for that setting here: Time Price Opportunity (TPO) Profile Charts: New Period at Day Session Start When Using Evening Session (1 Day Period Only) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
