Date/Time: Fri, 24 May 2024 06:57:27 +0000
Move DOM to different screen
View Count: 1045
[2020-01-02 22:57:46] |
User575399 - Posts: 305 |
I have a dual monitor setup. Is it possible to move just the DOM to one screen and have my charts on the other? I tried and the DOM seems “fixed” to the Sierra charts.
Date Time Of Last Edit: 2020-01-02 23:10:13
[2020-01-03 03:24:58] |
You have to Detach/Attach the Trading DOM, if it is not already, and then move the detached Trading DOM to the desired monitor. Refer to: Detaching and Attaching Chart Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-03 03:25:11
[2020-01-03 04:48:01] |
Is that to detach the chart or the DOM ? I just need the DOM detached so I can move it to the other screen opposite the chart.
Date Time Of Last Edit: 2020-01-03 04:55:41
[2020-01-03 17:25:05] |
User495158 - Posts: 106 |
When you want to move a chart or DOM to another monitor, you need to detach it first. So, dependant on what you want to move, you would detach it and move it to second monitor. The other option would be to open a second SC instance with a separate chartbook for the second monitor. Date Time Of Last Edit: 2020-01-03 17:27:22
[2020-01-03 19:21:05] |
What is unclear about this, is when you open a Trading DOM it is already detached. So we are puzzled about the question to begin with. Could you explain why it is attached?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-03 19:21:15
