Date/Time: Sun, 19 May 2024 05:43:06 +0000
multiple accounts from same broker
View Count: 1034
[2019-12-30 15:57:44] |
User859795 - Posts: 51 |
hello, I have a couple live accounts from AMP Futures, how can I trade them simultaneously? do I have to multiple Sierra instances or is there another way? thank you, Zoltan |
[2019-12-30 21:46:59] |
If they are connected with the same username, then you just need to select them on the Trade Window: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Otherwise, you need to use two separate instances of Sierra Chart: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
