Date/Time: Sat, 18 May 2024 11:37:11 +0000
Commission calcs not working in trade activity
View Count: 619
[2019-12-22 23:13:13] |
User200390 - Posts: 31 |
I have commission values set for the instruments I trade in global symbol settings but when executing trades the commission is not calculated - shows as 0 - in the trade activity.
[2019-12-23 00:15:54] |
Make sure you have enabled the custom symbol settings: Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings) And refer to: Trade Activity Log: Use Commission Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
