Date/Time: Tue, 14 May 2024 08:42:38 +0000
[User Discussion] - I have a problem with the moving average simple
View Count: 527
[2019-12-21 20:35:33] |
User703757 - Posts: 7 |
im using 2 moving average simples of 200 and 20 periods but they looks messy, i add a picture so you can see how they look, what can i do to fix this?. thanks
medias.PNG / V - Attached On 2019-12-21 20:34:21 UTC - Size: 110.55 KB - 248 views |
[2019-12-22 02:16:01] |
We are not sure exactly what you mean but just make sure that the Scale Range for them is set two Automatic or Same as Region: Chart Scale and Scale Adjusting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
