Date/Time: Sat, 05 Jul 2025 18:26:36 +0000
Rithmic connection not working (trial)
View Count: 1688
[2013-12-30 16:18:11]
Paul.M - Posts: 113
I am testing Rithmic.
I got log/pass from AMPfutures.
But Sierra can not connect to any of the Rithmic servers.
Only the Paper-server gets connected, but no market data is on the charts.
Please help.
[2013-12-30 17:01:00]
Post a copy of the Message Log, by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
[2013-12-30 17:52:46]
Paul.M - Posts: 113
Rithmic Trading - Port for executable: 3851 | 2013-12-30 18:49:22
Rithmic Trading - Starting server: F:\Programme\aaaa Trading\SierraChart6\Rim\DTCBridge.exe | 2013-12-30 18:49:22
Rithmic Trading: Connecting to the server 127.0.0.1. Port 3851 | 2013-12-30 18:49:23
Error received in OnConnect while connecting. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2013-12-30 18:49:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-30 18:49:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-30 18:49:24
Rithmic Trading: Disconnected from the server. | 2013-12-30 18:49:24
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-30 18:49:24
Rithmic Trading - Port for executable: 4363 | 2013-12-30 18:49:25
Rithmic Trading - Starting server: F:\Programme\aaaa Trading\SierraChart6\Rim\DTCBridge.exe | 2013-12-30 18:49:25
Rithmic Trading: Connecting to the server 127.0.0.1. Port 4363 | 2013-12-30 18:49:26
Error received in OnConnect while connecting. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2013-12-30 18:49:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-30 18:49:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-30 18:49:27
Rithmic Trading: Disconnected from the server. | 2013-12-30 18:49:27
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-30 18:49:27
Rithmic Trading - Port for executable: 4875 | 2013-12-30 18:49:28
Rithmic Trading - Starting server: F:\Programme\aaaa Trading\SierraChart6\Rim\DTCBridge.exe | 2013-12-30 18:49:28
Rithmic Trading: Connecting to the server 127.0.0.1. Port 4875 | 2013-12-30 18:49:29
The network socket is connected. | 2013-12-30 18:49:29
Rithmic Trading: Connected to server. | 2013-12-30 18:49:29
Rithmic Trading: Sending logon request message. | 2013-12-30 18:49:29
Rithmic Trading - Starting the connection process to data and trading service. | 2013-12-30 18:49:29
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2013-12-30 18:49:29
Rithmic Trading - Connecting to Rithmic 01 US server. | 2013-12-30 18:49:29
Rithmic Trading - Server Alert: Market Data Connection Opened. Error text: | 2013-12-30 18:49:32
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Error text: permission denied | 2013-12-30 18:49:32
Rithmic DTC Server Info - Server Name: Sierra Chart DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2013-12-30 18:49:32
Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-30 18:49:32
Rithmic DTC - Logon error from server: | 2013-12-30 18:49:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-30 18:49:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-30 18:49:32
Rithmic DTC: Disconnected from the server. | 2013-12-30 18:49:32
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-30 18:49:32
Rithmic Trading - Port for executable: 7947 | 2013-12-30 18:49:33
Rithmic Trading - Starting server: F:\Programme\aaaa Trading\SierraChart6\Rim\DTCBridge.exe | 2013-12-30 18:49:33
Rithmic Trading: Connecting to the server 127.0.0.1. Port 7947 | 2013-12-30 18:49:34
Error received in OnConnect while connecting. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2013-12-30 18:49:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-30 18:49:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-30 18:49:35
Rithmic Trading: Disconnected from the server. | 2013-12-30 18:49:35
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-30 18:49:35
Rithmic Trading - Port for executable: 8715 | 2013-12-30 18:49:36
Rithmic Trading - Starting server: F:\Programme\aaaa Trading\SierraChart6\Rim\DTCBridge.exe | 2013-12-30 18:49:36
Rithmic Trading: Connecting to the server 127.0.0.1. Port 8715 | 2013-12-30 18:49:37
Error received in OnConnect while connecting. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2013-12-30 18:49:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-30 18:49:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-30 18:49:38
Rithmic Trading: Disconnected from the server. | 2013-12-30 18:49:38
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-30 18:49:38
Rithmic Trading - Port for executable: 9227 | 2013-12-30 18:49:39
Rithmic Trading - Starting server: F:\Programme\aaaa Trading\SierraChart6\Rim\DTCBridge.exe | 2013-12-30 18:49:39
Rithmic Trading: Connecting to the server 127.0.0.1. Port 9227 | 2013-12-30 18:49:40
Error received in OnConnect while connecting. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2013-12-30 18:49:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-30 18:49:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-30 18:49:41
Rithmic Trading: Disconnected from the server. | 2013-12-30 18:49:42
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-30 18:49:42
Rithmic Trading - Port for executable: 9739 | 2013-12-30 18:49:43
Rithmic Trading - Starting server: F:\Programme\aaaa Trading\SierraChart6\Rim\DTCBridge.exe | 2013-12-30 18:49:43
Rithmic Trading: Connecting to the server 127.0.0.1. Port 9739 | 2013-12-30 18:49:44
Error received in OnConnect while connecting. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2013-12-30 18:49:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-30 18:49:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-30 18:49:45
Rithmic Trading: Disconnected from the server. | 2013-12-30 18:49:45
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-30 18:49:45
Rithmic Trading - Port for executable: 10251 | 2013-12-30 18:49:46
Rithmic Trading - Starting server: F:\Programme\aaaa Trading\SierraChart6\Rim\DTCBridge.exe | 2013-12-30 18:49:46
Rithmic Trading: Connecting to the server 127.0.0.1. Port 10251 | 2013-12-30 18:49:47
File >> Disconnect selected. | 2013-12-30 18:49:47
Rithmic Trading: Disconnected from the server. | 2013-12-30 18:49:47
The German part says: "Could not establish connection, since traget-PC refused connection"
[2013-12-30 17:53:32]
Paul.M - Posts: 113
what server should I choose ?
[2013-12-31 22:57:49]
This is the relevant error from the log:
We do not know what Server you should choose in Global Settings >> Data/Trade Service Settings. Please contact your broker about this.
Date Time Of Last Edit: 2013-12-31 22:58:14
