Date/Time: Mon, 13 May 2024 21:43:16 +0000
study display on chart
View Count: 533
[2019-12-21 04:18:56] |
User630795 - Posts: 86 |
it seems that vertical range of chart is automatically adjusted to display all studies. is there a way to stop this? for example, even if a higher period moving average list is too far from the price action, the chart still displays it on the chart making price action (candles) too crunched up. is there a way to allow the study that is too far from the price action not be displayed/visible on the chart? i hope this makes sense. thank you. |
[2019-12-21 04:44:24] |
Refer to: Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-21 05:15:34] |
excellent! thank you. |
