Date/Time: Wed, 15 May 2024 04:18:09 +0000
Pivot alerts...
View Count: 667
[2019-12-20 17:40:10] |
User629089 - Posts: 93 |
Hi, I'm trying to add alerts to the ETH daily pivot levels. I searched on the support board and found a response directing the person to the "Alert Formula Examples", specifically example 40. I've copied it exactly and it doesn't work. I've also added that exact formula to the "Color Bar Based On Alert Condition" study and it doesn't work there either. I've enabled/disabled them individually and tried them in unison and nothing works. Could you help? Also, I would like the alert to work not only if it crosses over but only if it touches the pivot. From an earlier question I submitted about adding an alert to the TICK, this did work under the "Color Bar Based" study: =OR(H>=1000,L<=-800) I don't know if that could be helpful as the numbers are static whereas the pivot levels change daily. Any help would be greatly appreciated. Thanks |
[2019-12-20 17:52:50] |
Ackin - Posts: 1865 |
Hi, tomgilb reply: Tick Low vs Price Low Alert or I did study for similar. You can download it as a finished ACSIL study Study: "Tick Nyse H/L" contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-06-24 22:51:34
