Date/Time: Sat, 27 Apr 2024 17:12:33 +0000
Drag multiple orders at once on DOM
View Count: 1570
[2019-12-20 06:42:58] |
T44 - Posts: 363 |
The feature I requested - that there be a user configurable option to move the nearest limit order to a price on the ladder by clicking that price - seems related to this. The click-drag-click or click-hold+drag-release method is slightly too slow for my coordination. Perhaps a modifier (shift+click or right click) could move all orders. Could be the same with stops depending on whether you're clicking in the buy or sell column. If this were possible in ACSIL I'd definitely try to code something up. Date Time Of Last Edit: 2019-12-20 06:43:33
[2019-12-22 05:56:34] |
The closest that is available is documented here: Order Types: Move Attached Targets to Price Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-22 10:50:23] |
T44 - Posts: 363 |
Thank you, that is useful, however still a multi click process. Could one of these options be modified to trigger the "move targets to price" feature? Could this be considered for paid development if you have capacity? |
10275-2019-12-22-1046.png / V - Attached On 2019-12-22 10:50:10 UTC - Size: 45.16 KB - 306 views Attachment Deleted. |
[2019-12-23 17:26:04] |
Yes we could add that capability. Please check back with us in about a week.
[2019-12-28 18:29:45] |
T44 - Posts: 363 |
Thank you, that is very helpful. Perhaps an option to configure so e.g. left click moves closest order to selected price and right click moves all orders?
[2019-12-28 23:29:04] |
nosast - Posts: 290 |
Also very helplful would be to have this feature available as a keyboard shortcut and a control bar button.
[2020-01-11 01:01:15] |
@SC Did you already add this feature in the current pre-release? If so - is a shortcut and control bar button also available?? Date Time Of Last Edit: 2020-01-12 02:20:55
[2020-01-12 02:28:03] |
You can also add it as a button on the DOM similar to flatten. I would rather use the move target to price to take me out than flatten in normal circumstances. Flatten would the really get an emergency out. As I trade ES it's a pretty solid assumption to get out one tick better.
[2020-01-16 18:47:10] |
T44 - Posts: 363 |
I'm on 2036 and I don't think anything has been changed/added?
10373-2020-01-16-1846.png / V - Attached On 2020-01-16 18:46:57 UTC - Size: 36.52 KB - 265 views |
[2020-01-28 13:05:44] |
@SC: Any update on this?
[2020-03-09 01:44:16] |
We will try to get this done this evening.
[2020-03-12 23:03:02] |
Hey SC, could you please describe how to setup a hotkey or button to move all targets to price? |
[2020-03-13 03:46:44] |
This is not supported.
[2020-03-13 06:26:04] |
And how is it then implemented to drag all the targets with one click?
[2020-03-22 04:01:08] |
You need to right click on the Chart to select the price at the same time: Order Types: Move Attached Targets to Price In the latest version, there are new Chart DOM options to move Targets or Stops to a price. Instructions to change those settings: Global Trade Settings Windows: Chart DOM Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
