Date/Time: Sat, 18 May 2024 17:04:25 +0000
ECIVwap do not works
View Count: 927
[2019-12-18 14:38:39] |
User928103 - Posts: 11 |
Hello Support, I tried to upload the ECIVwap.cpp file to my Sierra, which I downloaded from your page called User Contributed Advanced Custom Study System Source Code. I copied it to the Data folder. unfortunately I can't visualize it in custom Studies. Up until two weeks ago I had the Sierra version released by Transact and the ECIVwap package worked ... I also loaded the DLL and the .cpp file that I used with it but nothing works. Can you help me? Thanks. |
ecivwap.PNG / V - Attached On 2019-12-18 14:38:14 UTC - Size: 79.99 KB - 400 views |
[2019-12-21 01:04:15] |
Ackin - Posts: 1865 |
Hi I tried to upload the ECIVwap.cpp file to my Sierra, which I downloaded from your page called User Contributed Advanced Custom Study System Source Code.
The .cpp file is not a library but the source code.first try this: Menu/Analysis/Studies - Add Custom study -> User Contributed Studies .... ECIVwap If you don't have a library on the list you can find it here: Add custom study | Post: 200272 Perhaps it helped you. |
[2019-12-21 15:04:40] |
hello Ackin, thanks for your attention. User Contributed Studies were not present in my Custom Studies. My friend (and Sierra's client) Massimo copied his folder and turned it over to me. Now everything works perfectly. Thanks again for your kindness. |
[2019-12-23 17:46:01] |
Ok this is good. To install the User Contributed Studies you just need to enable Install Optional Components option on the installer program.
