Date/Time: Sat, 18 May 2024 23:12:16 +0000
Gain Data Stops after 4 ticks
View Count: 518
[2019-12-17 13:37:11] |
User70133 - Posts: 6 |
this is on an ESH20 Chart i can disconnect then reconnect and it moves but only for a few ticks then it stops again. please check this was happening yesterday as well.
[2019-12-17 13:54:41] |
Gain Capital has been notified about this problem.
