Date/Time: Sat, 18 May 2024 15:56:53 +0000
Pulling / Stacking
View Count: 623
[2019-12-17 11:32:50] |
User907968 - Posts: 804 |
Hi, Sorry I could not find an answer to this elsewhere. Are pulling/stacking values calculated locally within SC? If so, would it correct to assume that a lower chart (DOM) update interval would provide a more accurate picture of pulling/stacking? Thanks. |
[2019-12-17 13:24:20] |
Yes this is calculated within Sierra Chart but it is not affected by the Chart Update Interval. It is calculated at the end of a batch of market depth updates from the data feed. It is most accurate when using the Sierra Chart provided data feeds. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
