Date/Time: Sat, 18 May 2024 21:06:23 +0000
Shortcut to hide the Trade Services Log Window
View Count: 522
[2019-12-17 08:08:33] |
ycomp - Posts: 277 |
If you use a shortcut for Message Log Window then you can press it to show, press it again to hide. If you use a shortcut for a Trade Services Log window.. you can only show it, you can't hide it... unless you use a key combination like press the shortcut and then press Esc Would it be possible to add a toggling ability so that you can hide it also? Date Time Of Last Edit: 2019-12-17 08:09:44
[2019-12-17 13:57:44] |
Yes we will look into this.
