Date/Time: Sun, 05 May 2024 01:36:39 +0000
Update E3 of spreadsheet trading system
View Count: 1086
[2013-12-29 04:16:44] |
batman_ - Posts: 190 |
SC, Does E3 cell LTP update speed depending on chart update speed? Say if chart load at 500 ms, E3 cell is also updating at the same speed at 500 ms? |
[2013-12-29 07:10:44] |
Yes, this is a correct understanding.
[2013-12-29 07:55:10] |
If i added spreadsheet trading system to TradeDOM, would TradeDom's E3 cell update much faster than chart's E3 cell?
