Date/Time: Thu, 02 May 2024 09:34:45 +0000
Flash Drive
View Count: 1184
[2013-12-29 01:14:35] |
Richard Reyes - Posts: 98 |
I have copied the Sierra Chart folder to a flash drive so that I can carry the program and files with me to other computers. The program loads fine from the flash drive, but when I go to load a currency pair chart I just get a black (blank) screen. Please advise.
[2013-12-29 01:40:21] |
If you look at the Window >> Show/Hide Message Log, you will see what the problem is. Please look at it.
[2013-12-29 15:53:48] |
Thank you so much for the reply. Apparently when I moved the folder from my main computer to the flash drive , the path for the currency chart files was compromised. Any idea how I can setup the correct path to the new location? Many Thanks
[2013-12-29 16:20:32] |
Graham - Posts: 44 |
From the Global Settings Menu. Select General Settings and make sure the Data Files Folder path reflects the correct path to your flash drive. By default it should be C:\SierraChart\Data Assuming you copied the directory to the root of your flash drive and for instance has been given drive F: the path should be F:\SierraChart\Data |
[2013-12-30 10:41:19] |
The simple solution to this problem is to enable Global Settings >> General Settings >> Always Use Data Folder within Main Folder.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-30 10:41:36
