Date/Time: Fri, 03 May 2024 14:19:02 +0000
[User Discussion] - Data for Daily historic chart and Daily intraday chart is not matching
View Count: 1132
[2013-12-29 00:47:30] |
User19322 - Posts: 2 |
Hi, I opened a historic daily chart and an intraday daily chart for ESZ3 (Emini S&P 500) and the daily candles do not match up on both charts in several instances. Can you please let me know why this is happening? The first chart link is for the historic daily chart, the second chart link is for the intraday daily chart. http://www.sierrachart.com/image.php?l=1388277841589.png http://www.sierrachart.com/image.php?l=1388277873636.png |
[2013-12-30 00:49:46] |
User94740 - Posts: 333 |
Hi Support Team, I am experiencing this as well and wondering as to how the daily open and close times are being recorded by SC History Data. Would appreciate your help, because the daily charts are my main reference for trades. thx!
[2013-12-30 01:38:49] |
Refer to these two sections: http://www.sierrachart.com/index.php?l=doc/helpdetails43.html#h43.6 http://www.sierrachart.com/index.php?l=doc/helpdetails12.html#h12.2 Further questions on this are outside the scope of our support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-30 08:19:18] |
thank you for the quick response. I tried the suggestion in 12.4 which is to take the intraday data as a basis for the daily. The only drawback is the combine Sunday with Monday box function failing to work. Could you please help again?
