Date/Time: Wed, 08 May 2024 02:00:23 +0000
HISTORICAL INTRADAY TICK DATA
View Count: 1165
[2013-12-27 17:45:28] |
User82615 - Posts: 106 |
HELLO I'M LOOKING FOR A TICK DATA PROVIDER THAT COULD PROVIDE ME WITH FIVE YEARS OR MORE OF INTRADAY TICK DATA FOR DAX FUTURES TO BACKTEST INTRADAY TRADING FORMULAS IN SIERRA CHART. DO YOU RECOMEND ME ANY DATA SERVICE PROVIDER FOR THIS TO WORK IN SIERRA CHART? THANK YOU VERY MUCH |
[2013-12-27 18:17:22] |
We do not know of one that has 5 years of quality Tick by Tick data for the DAX. Possibly IQ Feed. You may want to check with them. Really our recommendation is to check with the exchange and see if you can get it in a text format and then you can import it into Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-27 21:12:56
