Date/Time: Tue, 30 Apr 2024 07:41:43 +0000
Earn 2 Trade Support
View Count: 1366
[2019-12-09 12:52:11] |
User940942 - Posts: 9 |
My paid subscription ended, but I am still not able to connect for free with the Earn2Trade account. I did go in and ensure that the "install option components" was enabled on the version I downloaded. I would like to get connected using the Earn2Trade free data. Thank you, |
[2019-12-09 16:56:33] |
Sierra Chart - Max - Posts: 5597 |
Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support |
[2019-12-09 17:39:12] |
Shouldn't I receive data free with Earn2Trade??? Based on the website, Sierra data is supposed to be free? Thank you |
[2019-12-09 20:02:02] |
You still need to pay for Sierra Chart usage time after your Sierra Chart trial expires.
[2021-05-11 16:01:11] |
User130077 - Posts: 9 |
Hi I am looking to use Earn 2 trade as my funded route, i understand they require rhithmic data feed but i am using SC or CQG, is there a work around for this Best Stuart |
[2021-05-11 17:26:07] |
Not at this time. There is new integration that will become available to Rithmic soon but it is not yet available.
