Date/Time: Sun, 05 May 2024 05:13:29 +0000
30 MP is different data than numbers bars
View Count: 956
[2013-12-27 04:32:18] |
User26059 - Posts: 19 |
Help this is not easy to describe. The prices are different between the 30 min Market Profile Chart(sc1.gif/TPO_RTH_LTTR) and the numbers bar chart(sc-nbars/ES-6 R T FP) See attached files. The M Period High = 1838 on the TPO chart and only 1837.75 on the ES-6 chart. Why are the two different? thanks James Date Time Of Last Edit: 2013-12-27 10:42:50
sc-nbars.gif / V - Attached On 2013-12-27 04:27:30 UTC - Size: 58.76 KB - 384 views |
[2013-12-27 10:49:14] |
Refer to the documentation for this here: https://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#PricingIncrementSettingEffect Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
