Date/Time: Mon, 29 Apr 2024 02:50:01 +0000
Getting error message
View Count: 1231
[2013-12-27 02:24:36] |
User46475 - Posts: 3 |
Software version: 1063 | 2013-12-26 20:20:53 Usage end date: 2014-01-08 | 2013-12-26 20:20:53 Enabled for: Sierra Chart Historical Data Service. | 2013-12-26 20:20:53 Active service: AMP/TTNet | 2013-12-26 20:20:53 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-12-26 20:20:53 2013-12-26 20:20:53 Local computer clock time | 2013-12-26 20:20:53 2013-12-27 02:20:53 GMT time | 2013-12-26 20:20:53 2013-12-26 20:20:53 Time zone adjusted time | 2013-12-26 20:20:53 Time difference to server time: 0 seconds. | 2013-12-26 20:20:53 Program path: C:\SierraChart\ | 2013-12-26 20:20:53 Data Files path: C:\SierraChart\Data\ | 2013-12-26 20:20:53 OS Version Number: 6.2 | 2013-12-26 20:20:53 Checking for new symbol settings for ttamp | 2013-12-26 20:20:53 AMP/TTNet: Connecting. | 2013-12-26 20:20:58 Starting the Price Feed session. Connecting to 12.41.48.53 port 10501... | 2013-12-26 20:20:58 The network socket is connected. | 2013-12-26 20:20:58 TT Price Feed FIX Session: Sending the Logon message. | 2013-12-26 20:20:58 TT Price Feed FIX Session: Received a FIX message missing required field TargetCompID <56>. | 2013-12-26 20:20:58 FIX Message: 8=FIX.4.29=0018135=549=TT_PRICE34=152=20131227-02:20:58.21158=Unable to login to adapter AMPNON1ORPR: is not authorized to use FIX Adapter.. Please contact your System Administrator.18000=110=251 | 2013-12-26 20:20:58 TT Price Feed FIX Session: Received a Logout message. Text = Unable to login to adapter AMPNON1ORPR: is not authorized to use FIX Adapter.. Please contact your System Administrator. | 2013-12-26 20:20:58 TT Price Feed FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-12-26 20:20:58 TT Price Feed FIX Session: Logged out and disconnected. | 2013-12-26 20:20:58 Disconnected from TT FIX Price Feed session. | 2013-12-26 20:20:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-26 20:20:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-26 20:20:58 AMP/TTNet: Disconnected. | 2013-12-26 20:20:58 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-26 20:20:58 AMP/TTNet: Connecting. | 2013-12-26 20:21:03 Starting the Price Feed session. Connecting to 12.41.48.53 port 10501... | 2013-12-26 20:21:03 The network socket is connected. | 2013-12-26 20:21:03 TT Price Feed FIX Session: Sending the Logon message. | 2013-12-26 20:21:04 TT Price Feed FIX Session: Received a FIX message missing required field TargetCompID <56>. | 2013-12-26 20:21:04 FIX Message: 8=FIX.4.29=0018135=549=TT_PRICE34=152=20131227-02:21:03.67758=Unable to login to adapter AMPNON1ORPR: is not authorized to use FIX Adapter.. Please contact your System Administrator.18000=110=002 | 2013-12-26 20:21:04 TT Price Feed FIX Session: Received a Logout message. Text = Unable to login to adapter AMPNON1ORPR: is not authorized to use FIX Adapter.. Please contact your System Administrator. | 2013-12-26 20:21:04 TT Price Feed FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-12-26 20:21:04 TT Price Feed FIX Session: Logged out and disconnected. | 2013-12-26 20:21:04 Disconnected from TT FIX Price Feed session. | 2013-12-26 20:21:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-26 20:21:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-26 20:21:04 AMP/TTNet: Disconnected. | 2013-12-26 20:21:04 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-26 20:21:04 File >> Disconnect selected. | 2013-12-26 20:21:07 AMP/TTNet: Disconnected. | 2013-12-26 20:21:07 Is this problem a glitch on Sierra Chart side or Amp/TTnet side |
[2013-12-27 02:30:13] |
Please contact AMP and let them know you are getting this message: Unable to login to adapter AMPNON1ORPR: is not authorized to use FIX Adapter.. Please contact your System Administrator. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
