Date/Time: Tue, 30 Apr 2024 03:57:42 +0000
[User Discussion] - support for multiple TWS instances
View Count: 658
[2019-12-01 21:02:02] |
User12089 - Posts: 350 |
this effectively says that 1 SC instance -> 1 TWS instance Interactive Brokers Trading Service: Running Multiple TWS Instances my question is: is there are a setup (e.g. chained SC instances via DTC etc whatever) and/or config of single SC instance, which would allow to link a single SC instance to two or more TWS instances in order to send the SAME trading order from a single SC instance to each of the TWS instances ? |
[2020-02-20 01:27:23] |
User401511 - Posts: 33 |
Yes it would be nice to have a resolution to this query. did you get an answer somewhere else?
[2020-02-20 10:53:01] |
No, this is not supported. You just need to have multiple accounts that the TWS instance is handling and then you can submit orders to them.
[2020-02-20 12:10:07] |
"just" haha .....
