Date/Time: Fri, 03 May 2024 04:47:24 +0000
Flatten on condition
View Count: 902
[2019-11-30 13:56:01] |
User275592 - Posts: 97 |
Hi, i am looking for a way to close (crash) position when a certain amount of ticks is lost i do not want to use stop loss Could you help me find a solution, i'm lost ! I have no experience of spreadsheet or acsil but i'm ok to learn one of them, or both Thank you for your help |
[2019-11-30 17:49:03] |
Why not use a stoploss order?
[2019-11-30 18:53:47] |
Thank you for your message I just don’t want to ´display’ my stop level on the market I’m scalping And my stop loss is very narrow |
[2019-12-01 03:14:21] |
Therefore, refer to: Order Types: Stop with Last Triggering Global Profit/Loss Management Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-01 19:39:32] |
Hi, Thank you for your message I will study ;-) the "stop with last triggering" order type, it seems great ! Sorry, but i did not understand your second link to globalPL Thank you for your GREAT help |
[2020-02-05 21:53:10] |
Hi, everything is ok with stop with last triggering :-) except the button BE which does not work Have you a solution ? Thank you for your help Date Time Of Last Edit: 2020-02-05 21:53:38
[2020-02-06 19:20:57] |
We see no reason why you cannot move that type of stop to break even. Is that stop order an Attached Order?
[2020-05-08 18:40:32] |
Hi, I retried and when i click on the Breakeven button, noting happens Thank you for your help |
[2020-05-08 20:09:01] |
Do you notice any problem when using Trade Simulation Mode and a replay with moving the Attached Stop order to break even?. Refer to: Replaying Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-09 07:01:27] |
Hi, I tested on a replay session of ES Stop on "StopLastTrig" Clicking on the BE button does nothing with exactly the same setup except stop on "stop", the BE button does "BE" Thank you for your help Renaud |
[2020-05-12 12:25:49] |
We will resolve this in the next release.
[2020-05-13 07:49:07] |
Thank you !
