Date/Time: Sat, 04 May 2024 03:13:20 +0000
Chart margin and scaling
View Count: 532
[2019-11-29 17:50:52] |
User912279 - Posts: 102 |
Dear Sirs, 1) Is there Setting to make the spacing on the side of the charts even smaller? (see depiction attached). 2) Why is it possible with some ES Futures Charts to make the scaling 0.1, instead of 0.01 increments, but not with all charts? |
SierraChartMargin.png / V - Attached On 2019-11-29 17:50:01 UTC - Size: 16.7 KB - 195 views |
[2019-12-01 02:53:14] |
1. No. 2. Refer to the Scale Increment setting here: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-01 16:04:04] |
Thank you. I've read thru all your materials. For everyone else reading this post the simple answer: is the "Auto-Set From Data Feed" ticked or not in the Chart Settings menu (F5). See picture. As for point 1, there must be a reason why some chart have a much broader empty margin (see Empty margin difference picture). Both charts have the same content, just in different time frames. Yet one has double as bi an empty margin as the other. The phenomenal is visible on many charts. Why is that? |
AutoScale.png / V - Attached On 2019-12-01 15:53:11 UTC - Size: 14.47 KB - 208 views EmptyMarginDifference.png / V - Attached On 2019-12-01 16:03:51 UTC - Size: 13.64 KB - 216 views |
