Date/Time: Mon, 29 Apr 2024 05:09:25 +0000
Direct way to access other chart parameters (from ASCIL) ?
View Count: 526
[2019-11-29 16:53:56] |
jesslinn - Posts: 108 |
Is there a direct way to access the chart parameters of a different chart, such as the ChartDataType, IntradayBarPeriodType, and the IntradayBarPeriodLength? The use case for this is to allow the user to set up a second chart with some desired configuration, provide it via a GetChartNumber input, and thus communicate the desired bar type and settings to the calling study. An indirect approach to this is to add a study to the second chart that provides the required parameters via persistent variables. This support request is just asking if there is or could be a direct way to get this information such as GetChartParametersFromChart( s_ACSOpenChartParameters& Parameters ). |
[2019-12-01 02:55:52] |
We can only refer you to the documentation here for the functions currently available: https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html For what you specifically need the answer is no. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
