Date/Time: Mon, 06 May 2024 12:00:44 +0000
Trade Orders Window black after upgrading
View Count: 861
[2019-11-29 01:55:14] |
User553714 - Posts: 184 |
Trade Orders window is black on all 6-installations I recently upgraded to V2017, can this be fixed?
Picture1.png / V - Attached On 2019-11-29 01:54:09 UTC - Size: 16.04 KB - 373 views |
[2019-11-29 03:54:28] |
Refer to the color settings here: Trading Information Windows: Setting Colors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-29 04:38:12] |
Thanks; I tried the instructions you refered me to and the colour for the "General Text Window Background Color" was already white in the settings but TradeOrders Window is still black; If I change to say colour yellow it changes to yellow background on the other Windows like Trade Servce Log, Message Log but not the TradeOrders window which stays black. Please note that I have never used these settings to change from the default colours and have always used the default white background, it only changed after upgrading to v2017 and is only black on the TradeOrder window.
[2019-11-29 05:03:23] |
Specifically refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#FontAndColors You need to close and reopen the Trade Orders Window after changing color settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-29 05:09:14
[2019-12-01 10:07:43] |
T44 - Posts: 363 |
I have the same issue after trying all the steps suggested above. Please see screenshot. (the graphics settings and trade orders window belong to the same sub-instance)
10149-2019-12-01-1006.png / V - Attached On 2019-12-01 10:07:12 UTC - Size: 30.9 KB - 356 views |
[2019-12-02 14:23:37] |
In version 2020 if the foreground and background colors are the same for the Trade Orders Window they are now reset to default. So the easiest thing to do is just update to version 2020. The relevant color settings are documented here: https://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#FontAndColors The settings you show in the Graphics Settings window are not the right ones. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-02 14:24:55
