Date/Time: Fri, 03 May 2024 01:11:46 +0000
Export DrawingsData
View Count: 718
[2019-11-28 21:44:17] |
User519919 - Posts: 6 |
Hello, it is possible to export the Graphics-Data in a text file or something else? I needed for my research. All Data that i needed i found it on "Manage Drawings" but i can't copy it. best regards Christian |
[2019-11-29 15:41:42] |
So do you just want to be able to export all of the drawing data that you see within the Manage Chart Drawings window? It might not be too difficult for us to add a command for that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-29 15:41:56
[2019-11-29 15:54:29] |
Hello, yes, this is it, what iam searching for. I will very thankfully. thank you ! best regards Christian |
[2019-11-29 16:44:41] |
User884550 - Posts: 149 |
and import into another PCs installation chartbook? that would be nice
[2019-12-04 20:21:03] |
Hello, @SierraChartSupport: Do you know when you have been added this little function in the software? best regards Christian |
[2019-12-11 19:05:49] |
Sierra_Chart Engineering - Posts: 14188 |
We will try to get this into the next release. It should not be difficult. and import into another PCs installation chartbook? that would be nice No, something like this is just too involved for us to be adding now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-11 19:07:36
