Date/Time: Thu, 02 May 2024 17:30:08 +0000
Evening session
View Count: 597
[2019-11-28 19:12:47] |
User472677 - Posts: 316 |
Hi, I had not updated for a while. After update to the latest version, ycharts that were setup to include evening session, no longer include evening session. I can go to her properties and change it to evening session. But when I change the symbol it goes back to no evening session. I have tried to go through general settings and put evening session for some symbols ?, ?? ??? ????. Still when I enter new symbols, there is no evening session. I want evening session to be default for all symbols. I think general settings should work but o may not be going something right. |
[2019-12-01 03:03:48] |
Make sure you have set the Symbol Settings correctly: Global Symbol Settings: Instructions And be sure to follow step 9. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
