Date/Time: Tue, 30 Apr 2024 03:18:24 +0000
error after replacing PersisVars
View Count: 621
[2019-11-28 11:05:43] |
User275592 - Posts: 97 |
Hi, I am trying to compile an old study for the 64-bit version of SierraChart I replaced "PersistVars" by "GetPersistentInt" in the following line of code : "int& MenuID1 = sc.PersistVars->i1;" I get an error : "error C2227: left of '->i1' must point to class/struct/union/generic type" when i compile the new code "int& MenuID1 = sc.GetPersistentInt->i1;" Thank you for your help |
[2019-11-28 13:27:04] |
User907968 - Posts: 802 |
It is explained here - sc.GetPersistentInt() for example - int& MenuID1 = sc.GetPersistentInt(1);
[2019-11-28 15:07:37] |
Yes the code example given in post #2 above is correct.
[2019-11-30 13:53:46] |
Thank you for your help SierraChart great platform, great support and great community :-)
