Date/Time: Tue, 14 May 2024 07:21:19 +0000
Call to sc.ApplyStudyCollection() always tries to add extension to provided filename
View Count: 451
[2019-11-27 20:57:34] |
User972768 - Posts: 166 |
Hello, I'm using sc.ApplyStudyCollection() in my study and it seems that there are 2 issues with this call: 1) regardless of provided file name, it always tries to add extension. Here is a snippet of sample code and record from the Message Log study_collection = "MovingAverageCrossover.StdyCollct"; status = sc.ApplyStudyCollection(chart_id, study_collection, 1); Error opening study collection file: C:\SierraChart_T0\Data\MovingAverageCrossover.StdyCollct.StdyCollct. Windows error code 2: The system cannot find the file specified. | 2019-11-27 15:18:49.533 * This code works fine if I remove extension from the filename like: study_collection = "MovingAverageCrossover"; status = sc.ApplyStudyCollection(chart_id, study_collection, 1); 2) It is just my assumption, that call to sc.ApplyStudyCollection() should return status if study collection has been applied successfully. Otherwise I would expect it to be void instead of int. If my assumption is correct, then there is a little issue of function always returning 1 regardless of actual result. Because of the 1st issue, inputs calls like SetPathAndFileName() can't be used as expected. Just for the reference, I'm on v2015. Thanks and Best regards Date Time Of Last Edit: 2019-11-27 21:00:48
