Date/Time: Tue, 14 May 2024 09:34:37 +0000
FRED data on SC?
View Count: 1080
[2019-11-27 00:55:28] |
User689221 - Posts: 20 |
Is there any way to connect FRED economic data to SC? I would like to be able to create custom charts using economic data (i.e. Treasury Cash Balances, M1/M2 money supply, etc.)
[2019-11-27 04:30:54] |
If the data format is in a text format you can create charts from it: Text/CSV Data Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-27 20:54:02] |
Is there any way to connect an excel sheet exported from FRED (via https://fredhelp.stlouisfed.org/fred/data/downloading/using-the-download-data-link/) into SC automatically? Or this method always requires manual updates that will take a lot of time to do every day / week depending on the data point. |
