Date/Time: Sat, 18 May 2024 00:21:37 +0000
Possible to change colors on the Statistics page?
View Count: 558
[2019-11-26 17:26:44] |
J4yTr4der - Posts: 20 |
I'm trying to get everything to run in a "dark mode" since Infinity Futures provides everything in a super bright white mode. Mostly this isn't very difficult, but I can't get the background of the Trade Activity Log Statistics Tab to change. I can change the general window background color, but the text areas are all still on a white background with black text. Is there a way to change these colors and if so, how? |
[2019-11-26 17:39:31] |
You can change that. Refer to: Graphics Settings: Setting the Background Color, Text Color, and Font for Text Only Windows However, it sounds like you are already aware of the settings. In which case we want you to post a screenshot of the Trade Activity Log Statistics tab so we can see what you are referring to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-26 17:47:20] |
Yes I am unable to change this one thing. Here is a screenshot showing what I can change (the General Text Window Background Color, seen dark here) and what I can't (anything else).
Date Time Of Last Edit: 2019-11-26 17:47:34
TAL Stats Colors.PNG / V - Attached On 2019-11-26 17:46:50 UTC - Size: 83 KB - 228 views |
[2019-11-26 17:55:13] |
Ok we will solve this, but the solution is just to restart Sierra Chart.
[2019-11-26 18:08:20] |
Thanks but I'm confused... the solution is just to restart SC? I've done that but nothing is different. What am I missing here?
