Date/Time: Wed, 01 May 2024 15:25:14 +0000
Volume subgraph drawing extends onto main graph
View Count: 635
[2019-11-26 01:44:42] |
User19165 - Posts: 346 |
I don't know how else to describe this. Has happened several times in the past and starting to become annoying. Please see the attached image highlighting the issue.
MK-2019-11-26_144237.png / V - Attached On 2019-11-26 01:44:31 UTC - Size: 27.45 KB - 248 views |
[2019-11-26 05:14:19] |
We do not see how that is technically possible, duplicate that chart (Chart >> Duplicate Chart) and remove all other studies, and see if you still notice this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-26 05:14:31
[2019-11-26 05:26:34] |
I did this several times. Removing studies seems to make this anomaly go away, but I do not find the reason for it to go away to be consistent, ie, the same study removed from one instance to another does not consistently make the anomaly go away.
[2019-11-27 01:33:50] |
Technically, this is possible because it is happening sometimes. Do you have any suggestions other than removing all my studies and tediously re-adding them all?
[2019-11-27 04:44:14] |
Provide us that particular chart and we will test it. Here are instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-27 04:44:21
[2019-11-27 08:41:11] |
Its easier just to give you the "production" chartbook because it has studies that depend on other charts. The recent problem shows up 2 days ago on the 5 minute chart.
Private File |
[2019-12-01 04:43:17] |
What you are seeing is drawn by one of the studies in particular study with ID 3 on chart number 4. Why do you have that? Just remove it.
