Date/Time: Sat, 04 May 2024 23:50:13 +0000
Flatten Positions etc
View Count: 545
[2019-11-25 15:49:11] |
Aditya Chopra - Posts: 21 |
Hi, Three questions - Can I set a time when all orders, positions are flattened and cancelled. - How can I remove some of the configurations from the attached order list - In the SET tab of Trade window, what does "Max Chase for Chase Limit Orders" and "Trig Limit Offset) means Regards |
[2019-11-26 05:25:53] |
1. Refer to the following: Global Profit/Loss Management 2. Do you mean you want to remove a saved Trade Window configuration from the drop-down list of configurations? 3. Refer to the following: Basic Trading and the Trade Window: Trade Window 'Set' Tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
