Date/Time: Sat, 27 Apr 2024 18:56:32 +0000
v2011: Separate subscription for market depth updates not supported
View Count: 1235
[2019-11-25 00:31:38] |
uM8137 - Posts: 180 |
from the SC log, while using SC Data Service(bookmap): DTC client #26. dtcserv/cli. 127.0.0.1 | Received subscribe to market depth for symbol NQZ9-CME | 2019-11-24 18:25:22.350
SC Data - All Services | Starting real-time market data updates for: NQZ9-CME. ID: 39 | 2019-11-24 18:25:22.351 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: NQZ9-CME | 2019-11-24 18:25:22.351 SC Data - All Services | Requesting security definition data for: NQZ9-CME. ID: 39 | 2019-11-24 18:25:22.351 Requesting market depth updates for: NQZ9-CME if supported. | 2019-11-24 18:25:22.351 Separate subscription for market depth updates not supported. NQZ9-CME | 2019-11-24 18:25:22.351 Subscribing to market depth over DTC used to work fine in v1997. But now in v2011, it appears... that it does not. What is going on? |
[2019-11-25 02:13:08] |
The problem in this particular case is this symbol does not correspond to SC Data-All Services: NQZ9-CME It is a Rithmic symbol. It needs to be NQZ19 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
