Date/Time: Sat, 18 May 2024 23:12:37 +0000
Connecting SC Data Feed to an external program for real time data
View Count: 979
[2019-11-21 05:58:25] |
User837373 - Posts: 1 |
Hi I had a question about the Sierra Charts Data feeds. Is it possible to use/connect the data feed to an external program (besides SC). I have an external program that can't be turned into a SC indicator so I would like to get 2 data feeds - one for SC and the other for my custom algo. Is this possible? I would need to get a real time data feed for my algo and I'm happy to pay a higher fee for this second data connection Thanks |
[2019-11-21 14:38:02] |
Yes you can access the data through the DTC protocol server within Sierra Chart: Data and Trading Communications (DTC) Protocol Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
