Date/Time: Sat, 04 May 2024 01:51:19 +0000
Volume by Price From Start Date-Time to End problem ?
View Count: 1969
[2013-04-12 08:38:30] |
wwwingman - Posts: 185 |
Hi, I am having a problem adjusting volume by price drawings, when the volume graphe period type is set to "From Start Date-Time to End". Is this a bug, or me doing something wrong ? W. Date Time Of Last Edit: 2013-04-12 09:16:41
VolumeByPriceCannotAdjust.cht - Attached On 2013-04-12 09:16:34 UTC - Size: 32.79 KB - 690 views |
[2013-04-12 08:42:28] |
What kind of adjustment are you doing and how are you doing it?
[2013-04-12 09:04:53] |
I would like to use the left mouse button in order to adjust the first left bar used as the beginning of the profile. The selection does not work after switching to the Start Date Time to End. I would like to use the right mouse in order to choose the profile settings. Same problem. Here is what I do. I draw a profile, it is set by default to Start-Date-Time to End-Date-Time. Selection works ok. I change the mode to Start-Date-Time to End. Selection with mouse stops working. I change the setting of the profile (through studies) back to Start-Date-Time to End-Date-Time. Selection with mouse does not work neither. W. Date Time Of Last Edit: 2013-04-12 09:05:36
[2013-04-12 16:40:29] |
We will check on this. This could be by design.
[2013-04-13 03:25:54] |
Al SC Developer - Posts: 434 |
This was by design. In 965, you will be able to use Start-Date-Time-To-End in addition to the currently allowed Start-Date-Time-To-End-Date-Time. |
