Date/Time: Sun, 19 May 2024 00:53:48 +0000
Current Price Scrolling off botom/top of chart(s)
View Count: 611
[2019-11-20 23:36:10] |
User48273 - Posts: 8 |
I can't find a way to stop the current price action from scrolling off the top or bottom of my charts. I am constantly having to go to the prices on the right of the chart and use the control key to move the viewable window of the chart up or down to see current price action. There has got to be a way to tell Sierra Chart to scroll the chart automatically so that the current price action is always on the chart. I use 5 charts and this is really cumbersome to manage. Thanks For your Help |
[2019-11-21 17:08:43] |
The reason this has happened is because you have already shifted the scale off of the default center or the Scale Range is not set to Automatic. Trying to manually readjust is not the right approach. Refer to: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
