Date/Time: Sun, 19 May 2024 07:45:18 +0000
Looking for a time study that will act similar to volume study
View Count: 483
[2019-11-20 21:17:42] |
User150852 - Posts: 38 |
I would like to place on a p&f chart or renko chart a study to show time that passed for the current p&f X or 0, or for current renko brick. similar in logic as the volume study that shows the volume of the current X0 or brick. probably the time scale should be controlled automatically for p&f as the unit can go from minutes to months. for renko probably minutes is good enough. Can it be done? |
[2019-11-21 17:14:32] |
You would want to use the Bar Time Duration study. Refer to the documentation here: Bar Time Duration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
