Date/Time: Sun, 05 May 2024 04:17:36 +0000
ES 5 min. chart
View Count: 1162
[2013-12-23 18:21:43] |
Richard A Johnson - Posts: 10 |
Everyday I am having problems with 5 min. ES bar opens and closes. Primarily closes. Almost always within the 1st 5 bars there's one or two wrong. I have to do a delete all data and download to get correct information. Then regularly throughout the day I get a half a dozen or so bars that open 1 tick above or below where they are suppose to. Again I do delete all data and download to correct. This happens with other charts and other markets as well. Any recommendations on how to correct this? Thank You |
[2013-12-23 18:26:04] |
We recommend using the Sierra Chart Real-time and Historical futures data feed: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
