Date/Time: Sun, 19 May 2024 06:11:48 +0000
TPO Value Area Lines for DOM
View Count: 932
[2019-11-20 14:07:22] |
User424077 - Posts: 38 |
SC, can you please add TPO Value Area Lines study to the trading DOM. TPO Value are more frequently used in the futures world over Volume Value. It will make a great enhancement for the DOM traders. Thanks. |
[2019-11-21 09:51:02] |
ticinotrader - Posts: 378 |
Hi, you can overlay virtually any study on the DOM using the 'Study/price Overlay Study'. It works with the TPO Value Area Lines study as well. You simply need to run a chart in the background with the TPO Value Area Lines study added, then reference it from the DOM using the Overlay Study. Hope this helps.
Date Time Of Last Edit: 2019-11-21 09:52:11
[2019-11-21 11:30:36] |
Hello, yes I’m aware it’s possible to use overlay, however when you’re dealing with many DOM charts open it becomes cumbersome to deal with all the related background charts where the study is copied from. Thanks. |
[2019-11-21 14:40:31] |
You can do this now: Chart Trading and the Chart DOM: Adding Studies on a Trade DOM Any study can be added . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-21 14:40:40
[2019-11-21 14:44:12] |
Actually we understand why you cannot add that particular study . We will add this to the list.
