Date/Time: Sun, 19 May 2024 06:58:28 +0000
Tradovate and Sierra
View Count: 1397
[2019-11-20 12:15:24] |
User135370 - Posts: 160 |
Tradovate use CQG I currently use Denali with another broker. I want to switch to Tradovate but don’t want to use CQG. Obviously I want to continue using Sierra. What are my options
[2019-11-20 19:47:43] |
There is no other option since Tradovate uses CQG.
[2019-11-20 19:48:10] |
If you still change to Tradovate, you would need to use CQG for the trading, but you can still use the Denali Exchange Data Feed for your data. Your other option is to stay where you are, with AMP, the Sierra Chart Order Routing Service, and the Denali data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
