Date/Time: Tue, 07 May 2024 07:58:15 +0000
REST API for TT FIX Solution
View Count: 1140
[2019-11-19 16:26:41] |
User294333 - Posts: 5 |
Greetings, Looking to run a REST API for my TT FIX setup I currently have. This will (hopefully) let me chart through Sierra and run automated journaling via Journalytix. Contacted AMP and TT and both say that Sierra is the last place that needs to enable REST API for me to be able to accomplish this. What steps must I take to do this? Thanks. |
[2019-11-20 03:31:17] |
TT REST is not anything we can provide access to. There are different ways you can access the order fills. You can access them through the Trade Activity Log in Sierra Chart and also through Sierra Chart's DTC Server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-20 03:33:29
[2019-12-28 19:10:29] |
osaga - Posts: 53 |
Hey Were you able to connect Journalytix via Amp? Seems like a bit of a complicated process that isn't well documented for Sierra Charts. Thanks |
[2019-12-29 00:08:19] |
There is no direct support for this.
