Date/Time: Sat, 03 Oct 2026 21:21:38 +0000
Horizontal Ray Config
View Count: 1894
| [2019-11-18 12:05:11] |
| Critcendo - Posts: 11 |
Hey There, Relatively minor question. Is there a way to save the config for a horizontal ray to include the modified text when you quick load? If I save the horizontal ray in the screencap below (with TEST) and quick load the config to another ray, the TEST text will not copy over... I know it's small, if it can't be done no biggie. Thanks. Running v1991 http://www.sierrachart.com/image.php?Image=1574078516352.png |
| [2019-11-18 18:00:27] |
Yes, you can do this by giving the Configuration a name. Then that name is used as the initial text for each ray. Refer to the following: Chart Drawing Tools: Common Tool Configuration Settings and Chart Drawing Properties Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-11-19 11:59:46] |
Don't know if the 'Thank You' button does anything, so I just want to say thank you again! I absolutely adore the platform and the support your team provides! EDIT: Is it possible to do this with the extending rectangle too? I don't see the 'label' tab for that tool's config. The horizontal ray global config does though! Date Time Of Last Edit: 2019-11-19 12:28:30
