Date/Time: Sat, 03 Oct 2026 21:21:25 +0000
Can Rectangle be forced to front of Study Subgraphs Reference
View Count: 863
| [2019-11-16 19:36:50] |
| User682444 - Posts: 12 |
If I draw a Rectangle it will disappear behind a Study Subgraphs Reference. I would like the Rectangle to be on top http://www.sierrachart.com/image.php?Image=1573932897125.png |
| [2019-11-17 03:46:31] |
Refer to: Chart Drawing Tools: Controlling Display Order of Chart Drawings Relative to Graphs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
