Date/Time: Tue, 30 Apr 2024 12:37:45 +0000
Relative spread for a given volume
View Count: 1395
[2013-12-22 14:12:47] |
working4coins - Posts: 3 |
Hello, I'm trying SC for trading Bitcoin. I would like to display relative spread for a given volume. spread_rel = 200.0 * (ask - bid) / (bid + ask) where bid is bid price for a volume V and ask is ask price for a volume V Ideally I would like to display it numerically and also to draw it I ever saw Analysis / Studies / "Time and Sales Bid&Ask" but I think it's only for highest bid and lowest ask. Moreover it's an absolute difference... not a relative difference. Kind regards Date Time Of Last Edit: 2013-12-22 14:36:59
[2013-12-22 20:03:40] |
So what exactly is the question? Do want to know how to access the current market depth data and how to draw text on a chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-22 20:25:49] |
Yes that's both questions... (calculating using orderbook depth) and drawing text on a chart. If I could also plot this spread_rel value it will help me a lot to understand how SC works. Thanks. Date Time Of Last Edit: 2013-12-22 20:28:47
[2013-12-23 18:29:39] |
Refer to these two sections in the documentation: http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scSymbolData http://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-23 18:30:27
