Date/Time: Sat, 03 Oct 2026 20:19:38 +0000
CQG Desktop with v2007
View Count: 1241
[2019-11-11 16:19:25]
User138602 - Posts: 185
Greetings,
I updated SC and its now running on 2007. But everytime i try to login to my brokers web UI (CQG via AMP), SC gets disconnected.
If SC logs in, then CQG logs out and the msg is something about a conflicting login.
So is CQG only accepting 1 active login from now on or did v2007 screw something up?
It worked perfectly before the update.
Can anyone confirm this?
Thx
Date Time Of Last Edit: 2019-11-11 16:21:24
[2019-11-11 17:25:56]
This is not within our control.
What we recommend you do though is switch to the SC order routing service:
Sierra Chart / Trading Technologies Futures Order Routing Service
And then very soon and we know we have talked about this for a while, we are going to have our own web-based trading panel which you can use at the same time and be logged into any number of times.
Date Time Of Last Edit: 2019-11-11 17:26:51
[2019-11-11 17:37:19]
Thats the ONLY! reason i am not using your order routing yet: the missing web trading panel. Any ETA?
[2019-11-12 05:01:28]
We are going to be resuming work on this in the next few days.
[2019-11-12 22:15:03]
Will you be able to release the direct order routing with the web interface?
Whats the current state of developement of the direct exchange routing?
