Date/Time: Sat, 03 Oct 2026 20:19:35 +0000
Chart lag issue
View Count: 1144
[2019-11-11 15:51:40]
User600643 - Posts: 4
I am experiencing chart lag at times of increased activity on the two markets that I trade - CL & ES. I have not always seen the behaviour. I have enjoyed using Sierra up until this started to happen but I can no longer trust the software. Can you help before I give up and go elsewhere?
I am running version 2007 - 64 bit. The chart update interval is set to 450ms. My computer is an I7 -6500U with 8gb memory
[2019-11-11 17:15:22]
Yes we can help you. The problem is with the Transact data feed. This is not a Sierra Chart data feed. You need to use the Denali exchange data feed instead:
Denali Exchange Data Feed
Let us know if you need help getting set up with this but the setup instructions are on that page.
Date Time Of Last Edit: 2019-11-11 17:15:41
[2019-11-12 15:15:11]
I followed the instructions (I think) but I receive no data and the next time that I log in to Sierra the data feed has reverted to TransactWS again - could you please help with that?
[2019-11-12 15:34:42]
We would like to call you to look into this. Is this a good time for you?
[2019-11-12 15:39:32]
Now is fine - I'm on +447769711362
[2019-11-12 16:07:28]
We apologize for the delay. We are calling now.
[2019-11-12 16:21:52]
User called. They did have the Denali data feed that are properly and all is fine and correct.
Date Time Of Last Edit: 2019-11-12 16:22:03
