Date/Time: Sat, 18 May 2024 09:53:42 +0000
Bid and Ask studies
View Count: 596
[2019-11-11 10:10:47] |
BenjFlame - Posts: 305 |
Hello, I have 2 questions: 1) "Time and Sales bid size" study displays an evolving plot of the best bid. Is it possible to have same kind of real time plot but calculated on latest x levels instead of only best bid? 2) "Bid & Ask Depth Bars" study: As you can see on image I set it to plot "Bid Depth vs Ask Depth" on ES. I don't understand the resulting plotted graph with values over -6000/6000 where I set the chart with a max depth level of 3 on the ES, which should result at max in a few hundreds max quantities on either side. Could you please explain results of 2)? Thanks, Benj |
bidask.PNG / V - Attached On 2019-11-11 10:10:20 UTC - Size: 189.67 KB - 258 views |
[2019-11-12 04:47:04] |
1. Have a look at this study: Bid & Ask Depth Bars 2. This is not within the scope of our support. The result must be accurate based on the settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-12 09:30:58] |
Ackin - Posts: 1865 |
BenjParis) Hi, I did a similar study. Study:Depth - filtered sides (vertical sum of levels) contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free update/upgrade page: Ackin's indicators (SCH users requests for studies) - Update list | Post: 193747 |
